In Stock?
DaveV
Hi, I just ordered the following parts for my R32 GTR in the shop. Can you confirm that they are in stock or not so i'll know when to expect them?
Alloy Subframe collars
Driftworks Hicas Lock bar
R32/Z32 Front upper camber arms
Thanks! :)
Bon Bon said:
Hi Dave,
Yes they were all in stock and you can expect them tomorrow. :) Already sent!
Great work!:dw:
I dont suppose you guys can get R32 GTR rear Hicas rods can you? Mine are worn at the inner end where they attach to the rack :(
Shite Shite Shite, I meant to order the slotted subframe collars but I must have hit the full ones, can you PM me about swapping them please? :o
Erm , can you also describe what each part of the Hicas lock kit in the picture here does, including the washers, bolts and nuts?
http://www.driftworks.com/catalog/images/large/HicasBar1.jpg
Just wondering if there is something in there to block the hydraulic lines?
Cheers :)
Basically it just comes with the mounting hardware, you don't want to block the hydraulic lines ideally as it'll kill the pump, just disconnect them and use a short length of leftover rubber hose to loop the metal pipes. Then it's like one gigantic power steering cooler too!! :D
