IS200 Coilovers ?
Robbs
FRANTIC
could you tell me if the HSD's listed for the Lexus IS200 will also fit the Sportcross model ? and if the difference is just spring rates can I specify a harder rate for the sportcross ?
also you have 2 sets of coilovers listed for the IS
Toyota Altezza SXE10
Lexus IS200 SXE10
chassis code for the Lexus IS200 is GXE10, just thought I'd point it out ;)
cheers :thumbs:
Keep finding conflicting information, I can't guarentee fitment I'm afraid.
No worries I've now had conformation that saloon coilovers fit the sportcross but Im not sure what spring rates to go for as most other coilovers specify 8kg-6kg but your saloon ones specify 12kg-10kg which I think would be far to hard but then I think I probably need slightly hard as its an estate ????
i dont have a estate but i do have a saloon is200 nd have recently fitted the HSD to it and i really really rate them stiff but not uncomfy unless you wanna go pothole hunting and easy as hell to fit just my 2 pence
I'd imagine the difference is negliable between the saloon/estate.
Can you you a 10/7kg if you want something a bit softer :)
