Madmax4life
Qty Item name SKU Item net Total net
1.00 Aluminium Crankshaft Pulley Large RCE4012/L £85.00 £85.00
1.00 ARP Rod Bolt Set RCE4010/2 £135.00 £135.00
1.00 Kent Race Valve Springs RCE4010/1 £110.00 £110.00
1.00 Alfaholics Aluminium Carburettor Mounts - Long 45mm FUL2004 £150.00 £150.00
2.00 Engine Mount HD - L R ENG3001/1 £39.50 £79.00
1.00 Water Pump - S4 Spider and 75 Twinspark COO006 £60.00 £60.00
1.00 Carb Rebuild Kit (Pair) - I NEED TO KNOW WHAT BRAND AND MODEL OF
CARBS YOU HAVE TO SEND YOU THE
CORRECT REBUILD KIT PLEASE
FUL013 £24.00 £24.00
1.00 Full Gasket Set No HG 2000cc ENG1006/4 £46.00 £46.00
1.00 Top Timing Chain Race ENG2041/1 £59.95 £59.95
1.00 Chain Tensioner Spring ENG2042/1 £6.00 £6.00
1.00 Chain Tensioner Bolt ENG2042/2 £3.75 £3.75
1.00 Chain Tensioner Lock Plate ENG2042/3 £3.00 £3.00
1.00 Bottom Timing Chain Race ENG2043/1 £42.00 £42.00
1.00 Valve Guide Seals Nord- Set 4 ENG1024 £10.00 £10.00
1.00 Big End Bearings Standard ENG2012 £32.50 £32.50
1.00 Main Bearings Standard ENG2022 £32.50 £32.50
1.00 Engine Thrust Washers - Standard ENG2027 £10.00 £10.00
1.00 Front Crankshaft Oil Seal -Corteco ENG2032/1 £6.95 £6.95
1.00 Rear Crankshaft Oil Seal - Corteco ENG2036 £13.00 £13.00
1.00 Spesso Race Head Gasket RCE4004 £87.50 £87.50
1.00 Door Mirror Round Type CHR001 £27.50 £27.50
16.00 Exhaust Manifold Nut EXH026 £0.95 £15.20
Subtotal £1,038.85
Exempt @ 0% £0.00
Total £1,038.85
Paid to date £0.00As you can see it been A expensive deal will be sending the build pics soon regards Ryan
