k1984w
Finally finished the car off few of u might have seen the build thread I put up here s full spec an proper pics from the finished built
Bare shell rebuild
Engine:
Full service redline oil engine, diff, transmission, iridium plugs
Wire tuck,Hks gt2540 turbo, Hks cams, Hks valve springs, Hks manifold, Sard 555cc injectors, Z32 afm, Metal head gasket, Sard fuel pump, tomei turbo elbow,nismo engine mounts,short shifter,fp gauge, Blitz bov, decat, Nismo exhaust, Greddy intercooler, Greddy front pipe, 3 layer rad with dual calsonic fans,nismo low temp thermostat,Apexi pfc+commander, oil cooler + relocation kit,Greddy boost controller, silkroad engine damper, Hks mushroom filter, iridium plugs,cusco oil catch can,tomie plug cover
Transmission:
1.5 way lsd, Triple plate clutch, lightened flywheel
Suspension
All bushings replacedvwith rsr bushing kit,R..Y.O fully adjustable coilovers, Cusco front tension rods, Cusco rear upper arms, Nismo lower arms, cusco rear suspention rods, driftworks subframe bushes, quick rack steering adaptor, front+rear strut bar, cusco 7 point cage
Brakes:
gtr skyline calipers and 5 stud hubs, stainless steel brake lines, a/m pads
Wheels:
Refurbished ssr vienna red cap, 18x9.5 +5, 18x11 -1, yokohama tires, lightweight wheel nuts
Interior:
Bride zeta fixed back, bride brix recliner, Bride door cards, glove box, gear gaitor, battery relocated to boot, razo gearkob, nardi steering wheel,Greedy boost, oil presure, water temp gauges, blitz turbo timer, pioneer double din,vibe 6x9s
Exterior:
Full re spray Audi brilliant red with 12 coats of laquer, under body understands and all running gear etc sprayed, 40mm origin front wings, 50mm gp sports rear arches moulded to body, fiberglass vented bonnet,Uras rear bumper an side skirts with origin front bumper,2 skid plates bumper+sump, 326 power wing, ganador mirrors,wind deflectors,aero catches,50/50 rear lights, raybrig clear front lights+sleepy eye, kazama clear repeaters, 8000k, tow hook
security:
Alot
Bare shell rebuild
Engine:
Transmission:
Suspension
Brakes:
Wheels:
Interior:
Exterior:
security:
Alot
