Jzx100 mark 2 drift shaft compatibility
Jzx_drew
Hello I’m currently going threw a manual swap on my 96 mark 2 grande 2.5 I have a w58 and I heard you could use the auto transmission drive shaft ? Does it need to be modified? . Also could you used internals from a brz 4.1 diff ratio in my oem pumkin (diff housing)
Hi Mate, Did you have any luck with your conversion? I am currently in the process of converting my jzx90 Chaser to manual. I have R154 out of a jzx100 and am curious about which drive shaft to use
