How’s it going everyone,
I’m have a problem with my jzx110 mark ii engine: 1jzGTE vvti
Gearbox: r154 manual swapped
Fuel: 255 walbro fuel pump
Intercooler: Blitz FMIC
Exhaust: 3” stainless cat back
Everything else is from factory
81000km
1000km on Irish roads
the problem I’m have started as a hesitation from 3k rpm to 4k rpm and after that it took off no problem
I changed spark plugs as I thought it was a problem from just old plugs but wasn’t then changed coils to C.O.P still not fix so then done the 255 walbro fuel pump and yet again that didn’t fix it so I then change spark plugs again and all of a sudden the car if breaking up when revving up the car from idle to 3k rpm and will not pass.
it is like a misfire(sounds like it) but I have 0 fault codes
I’ve done a compression test got 155psi across all cylinders
is there anyone that has experienced this problem before and could give some suggestions thanks a lot I will add a video of the car running
81000km
