Koyo radiators
We'll have more Koyo rads in stock hopefully tail end of next week. We'll have a couple that are the same as I have on my car now :nod:
You can use the standard viscous fan with it, but it's a bit of a squeeze.... I'll be changing to twin electric fans on mine soon as I get the chance.
the viscous one is good, but it gets pretty damn close to an uprated rad cos it's thicker and the viscous fan doesn't move as it's bolted to the engine.
On mine, the fan has skimmed the back of the rad slightly, but I did have a knackered engine mount.
A well setup twin electric fan and cowl will be slightly better overall than a viscous as it's cooling is linked to the coolant temp rather than engine speed.
Do you sell these for FD3S RX7? And do you know how direct a drop in they are....failing that do yuo guys do a fluidyne rad for the same car?
am i correct in thinking that from what your saying the s13 one will fit an r32?
and if so is it up to cooling an RBwhatever if it was designed for a CA/SR?
like its twice as thick as a skyline rad and made of ally, its up to cooling anything, the same core is used on all the koyo rads and its massive
