Lexus IS 200 Clutch, Which plate (organic, paddle, oem)? Opinions?
Christoph_is
I have a Lexus is200 however the clutch is slipping masively through 1st to 3rd under full throttle.
i know there's a couple of different brands that make the is200 clutch aswell as a paddle clutch and an organic clutch..
im just looking for something that will hold up a clutch kick every now and again, but not sure which one would be best for this.
Cheers Chris
if its completely standard then an organic exedy or similar will be fine.
check the condition of your flywheel though because the dual mass ones batter them selves into oblivion so you end up with loads of play.
get a genuine release bearing though as a cheap one will start squeaking and whirring after a few weeks.
i ended up putting the exedy organic clutch into the car in the end however surprise surprise the release bearing is squeaking everytime i push down/release the clutch peddle, im assuming im not doing any damage? its just the annoying sound right?
cheers
My clutch is also squeaking very annoyingly on my S13... Don't know how to cure without taking off the box (or cutting "window" in the bellhousing :D)
