uncrowded monarch
acc and sort code please
might come in handy
The Nissan engine family
This information concerns various specifications for most modern Japanese Nissan engines thru 1997.
E15-ET
Type: 1487cc EFI OHC 8-valve 4cyl turbo
Power: 115hp @ 5600rpm
Torque: 123ft-lbs @ 3200rpm
Gearboxes: FWD 5-speed and 3-speed auto
Source: 83-84 Exa and Pulsar Turbo
Z18-ET
Type: 1770cc EFI OHC 8 valve twin plug 4cyl turbo
Power: 135hp @ 6000rpm
Torque: 144ft-lbs @ 3600rpm
Gearboxes: RWD 5-speed and 3-speed auto
Source: 1982-83 Silvia ZSE-X and Gazelle
CA18-DE
Type: 1809cc EFI DOHC 16 valve 4cyl
Power: 130hp @ 6400rpm
Torque: 119ft-lbs @ 5200rpm
Gearboxes: FWD 5-speed and RWD 5-speed and 4-speed auto
Source: RWD 1988-on Silvia, FWD fitted to late model Australian EXA's
CA18-DET
Type: 1809cc EFI DOHC 16 valve 4cyl turbo
Power: 175hp @ 6400rpm (195hp @ 6400rpm 87-88)
Torque: 165ft-lbs @ 4000rpm (148ft-lbs @ 4000rpm 87-88)
Source: RWD intercooled examples come from 89-91 180SX and Silvia turbo. Non-intercooled RWD were 87-88 Gazelle engines. FWD examples come from 1988 Auster 1800Xtt (also not intercooled)
SR18-DE
Type: 1838cc EFI DOHC 16 valve 4cyl
Power: 140hp @ 6400rpm
Torque: 123ft-lbs @ 4800rpm
Gearboxes: FWD 5-Speed
Source: 92-93 Sunny GTS and Pulsar GTi (note bluebird version had only 93kW)
FJ20-E
Type: 1990cc EFI DOHC 16 valve 4cyl
Power: 150hp @ 6000rpm
Torque: 133ft-lbs @ 4800rpm
Gearboxes: RWD 5-Speed
Source: 1982-83 Silvia RS
FJ20-ET
Type: 1990cc EFI DOHC 16 valve 4cyl turbo
Power: 190hp @ 6400rpm
Torque: 165ft-lbs @ 4800rpm
Source: 1984 Gazelle RS-X, Silvia RS-X and skyline RS-X
L20-ET
Type: 1998cc EFI OHC 6cyl turbo
Power: 145hp @ 5600rpm
Torque: 151ft-lbs @ 3200rpm
Gearboxes: RWD 4-Speed Auto
Source: 83-84 Leopard TRX
VG20-ET
Type: 1998cc EFI OHC 12 valve V6 turbo
Power: 170hp @ 6000rpm
Torque: 159ft-lbs @ 4000rpm
Source: 83-84 Gloria V20
SR20-DE
Type: 1998cc EFI DOHC 16 valve 4cyl
Power: 160hp @ 6400rpm (145hp FWD)
Torque: 138ft-lbs @ 4800rpm (178 FWD)
Source: RWD 1993-94 Silvia Q's, FWD Presea
SR20-DET
Type: 1998cc EFI DOHC 16 valve 4cyl turbo
Power: 205hp @ 6000rpm (180SX), 220hp @ 6000rpm (Silvia), 230hp @ 6400rpm (Pulsar GTi-R)
Torque: 201ft-lbs @ 4000rpm (180SX), 201ft-lbs @ 4800rpm (Silvia), 209ft-lbs @ 4800rpm (Pulsar GTi-R)
Gearboxes: RWD 5-Speed and 4-Speed Auto (1993-on Silvia and 180SX) 4WD east-west 5-Speed (GTi-R)
Source: Silvia K's and 180SX after 1993, 1991-92 Pulsar GTi-R 4WD
RB20-DET
Type: 1998cc EFI DOHC 24 valve 6cyl turbo
Power: 215hp @ 6400rpm (auto 205hp @ 6400rpm)
Torque: 193ft-lbs @ 3200rpm (auto 195ft-lbs @ 3200rpm)
Gearboxes: RWD 5-speed and 4-speed auto
Source: 1989-1992 Skyline GTS and Cefiro Sedan
RB20-DE
Power: 155hp @ 6400rpm
Torque: 135ft-lbs @ 5200rpm
Source: 89-92 Laurel and Skyline
RB26-DETT
Type: 2597cc EFI DOHC 24 valve 6cyl twin turbo
Power: 280hp @ 6800rpm
Torque: 271ft-lbs @ 4400rpm
Gearboxes: 4WD North-South 6-Speed
Source: GODZILLA! HR32 GT-R 4WD
RB25-DE
Type: 2498cc EFI DOHC 24 valve 6cyl
Power: 180hp @ 6000rpm
Torque: 165ft-lbs @ 5200rpm
Source: 92-95 Cefiro and Skyline
RB25-DET
Type: 2498cc EFI DOHC 24 valve 6cyl turbo
Power: 250hp @ 6400rpm
Torque: 217ft-lbs @ 4800rpm
Source: 1993-on Skyline GTS-25t
VG30-E
Type: 2960cc EFI OHC 12 valve V6
Power: 180hp @ 5200rpm
Torque: 191ft-lbs @ 4000rpm
Source: 83-84 Gloria V30E
VG30-ET
Type: 2960cc EFI OHC 12 valve V6 turbo
Power: 230hp @ 5200rpm
Torque: 245ft-lbs @ 3600rpm
Source: 1983-on 300ZX turbo (considerably higher spec than Aust. Version)
VQ30-DE
Type: 2987cc EFI DOHC 24 valve V6
Power: 220hp @ 6400rpm
Torque: 205ft-lbs @ 4400rpm
Source: 96-97 Cedric and Gloria
VQ30-DET
Type: 2987cc EFI DOHC 24 valve V6 turbo
Power: 270hp @ 6000rpm
Torque: 270ft-lbs @ 4800rpm
Source: 96-97 Cima 30LV and 30TR
VG30-DE
Type: 2998cc EFI DOHC 24 valve V6
Power: 225hp @ 6400rpm (200hp @ 6000rpm auto)
Torque: 200ft-lbs @ 3600rpm (191ft-lbs @ 4400rpm auto)
Source: 1989 onwards 300ZX and Leopard
VH41-DE
Type: 4130cc EFI DOHC 32 valve V8
Power: 270hp @ 5600rpm
Torque: 277ft-lbs @ 4000rpm
Source: 96-97 Cima 41LV and LX
VG30-DET
Type: 2998cc EFI DOHC 24 valve V6 turbo
Power: 255hp @ 6000rpm
Torque: 252ft-lbs @ 3200rpm
Source: Nissan Leopard sedan around 1990-1991. No intercooler, single turbo
VG30-DETT
Type: 2998cc EFI DOHC 24 valve V6 twin turbo
Power: 280hp @ 6400rpm
Torque: 285ft-lbs @ 3600rpm
Source: 1989 onwards 300ZX twin turbo. Note: had twin intercoolers
VH45-DE
Type: 4494cc EFI DOHC 32 valve V8
Power: 280hp @ 6000rpm
Torque: 294ft-lbs @ 4000rpm
Source: 96-97 Infiniti Q45
Determining what year SR20DET you have......
Pull your ECU out... The ECU has a specific amount of wires from each side, lets say, the S14 ECU, upright, has 8/10/10/10 or 8/7/8/10, of course, thats dual layers... Sounds complicated? Well how about this. Look on your ECU, and count the number of wires coming out of each side, in each column, divided by a thick plastic (noticeable). Ok, now we got that, lets look at the chart of the engine years by ECU.
Chassis Year Engine Slots
S15 1999+ SR20DET 8/7/8/10
S14 1996-1998 SR20DET 8/7/8/10
S14 1993-1996 SR20DET 8/10/10/10
S14 1993-1998 SR20DE 8/7/8/10
RPS13 1996-1998 SR20DET 8/7/8/9
RPS13 1996-1998 SR20DE 8/7/8/9
RPS13 1991-1995 SR20DET 8/7/8/9
Ok, now you got the slots determined on your ECU, you can use this slot code to partially determine your engine model. Now its time to use the color code of your motor.
Chassis Year Engine Color
S15 1999+ SR20DET Black
S14 1996-1998 SR20DET Black
S14 1993-1996 SR20DET Black
S14 1993-1998 SR20DE Black
RPS13 1996-1998 SR20DET Black
RPS13 1996-1998 SR20DE Black
RPS13 1991-1995 SR20DET Red
Of course these are not the only determining factors, due to that some engines are equipped with VVTI, which are the newer motors, they will have the slant rear along with the frontal hump.
Chassis Year Engine Rear Slant
S15 1999+ SR20DET Yes
S14 1996-1998 SR20DET Yes
S14 1993-1996 SR20DET Yes/No
S14 1993-1998 SR20DE Yes
RPS13 1996-1998 SR20DET No
RPS13 1996-1998 SR20DE No
RPS13 1991-1995 SR20DET No
Chassis Year Engine Front Hump
Finally, one of the easiest ways to tell if you got a S15 motor, is by the gearing, but be aware, some engine sellers, might find some way to find a S14 motor, and a damaged S15 transmission, and combine it to get you to think you got a S15, use the ECU coding to check then... and after install, mostly a DYNO.
Chassis Year Engine Gear
S15 1999+ SR20DET 6
S14 1996-1998 SR20DET 5
S14 1993-1996 SR20DET 5
S14 1993-1998 SR20DE 5
RPS13 1996-1998 SR20DET 5
RPS13 1996-1998 SR20DE 5
RPS13 1991-1995 SR20DET 5
Nissan S13 chassis codes
S13 in general refers to the '88-'94 chassis. This includes the coupe and the fastback.
'88-'90 S13 Silvia CA18DET
'90-'91 RS13 180SX CA18DET (R for fastback)
'91-'93 PS13 Silvia SR20DET (P for SR)
'91-'98 RPS13 180SX SR20DET (no distinction between the two different minor model change, last minor change was the inclusion of the double round lights and a more squarish front bumper.)
'91-'93 KPS13 Silvia (K for SuperHicas)
'91-'93 KRPS13 180SX
'89-'90 HS13 240SX KA24E (H for KA24E)
'89-'90 RHS13 240SX FB
'91-'94 MS13 240SX (dunno chassis code for convertables)
'91-'93 RMS13 240SX FB(M for KA24DE)
'91-'93 KRMS13 240SX FB w/ SuperHicas
'91-'93 KMS13 240SX w/ SuperHicas (Canadian market only).
'94-'98 S14 Silvia SR20DET
'94-'98 CS14 Silvia w/ SuperHicas
'95-'98 S14 240SX KA24DE (no specific S14 code for KA24DE)
E15-ET
Z18-ET
CA18-DE
CA18-DET
SR18-DE
FJ20-E
FJ20-ET
L20-ET
VG20-ET
SR20-DE
SR20-DET
RB20-DET
RB20-DE
RB26-DETT
RB25-DE
RB25-DET
VG30-E
VG30-ET
VQ30-DE
VQ30-DET
VG30-DE
VH41-DE
VG30-DET
VG30-DETT
VH45-DE
S15 1999+ SR20DET 6
