Loads of guitar gear for sale. (Pic heavy)
Mark_McQ
Active Member
Some assorted guitar stuff for sale:
Gotoh Floyd Rose, fitted with FloydUpgrades big brass sustainer block, and an EVH D-Tuna.
Bought this lot a few weeks back as an upgrade for the crappy Edge 3 on my Ibanez RG, but it's not really suited to this guitar, the neck height coupled with the the trems depth aren't ideal for it, so I'm selling to afford an Edge Pro.
We have a gold Gotoh Floyd Rose, which I've upgraded with the brass sustainer block from FloydUpgrades. (See comparison pic below). It's also fitted with the EVH D-Tuna which lets you drop the low E down to D instantly. Also included is the trem stopper from FloydUpgrades which blocks the trem and makes it dive-only, so you can use the D-Tuna without tuning issues.
Comes with 2 post mounts and locking studs, trem claw, trem arm, and 4 springs. The original sustain block is also included, and is totally brand new and unused.
Everything is boxed and in brand new condition.
Cost me £217 all in, and then 32 quid of customs tax and Parcelforce's made up handling fees too on top of that.
Looking for £180 posted.
Pedaltrain JR Pedal board.
Rugged metal construction.
Dimensions:
17x12.5x2.5 inches
Comes with soft carry case. Also has mounts to fit Voodlab and BBE power supplies underneath. Two removable grommits on the rear to pass cables through.
£65 posted
Morley Little Alligator volume pedal.
Has knob on front to allow you to set a minimum volume. In good condition.
£45 posted.
Alesis Midiverb rack effects.
Awesome reverb and delays. Can also do the cool delay harmony thing from Steve Vai's Ballerina 12/24.
Full spec and info here:
MidiVerb4 Dual-Channel Parallel Processor
£80 posted.
Ibanez HD1000 harmoniser delay.
Old analogue 80's unit. Does various delays and harmonies. Non-intelligent harmoniser. Delays settings can be used to create flange, vibrato and chorus type effects.
Has an IEC plug on the power cable, I was running it off a conditioner, will need a regular plug put back on if you're using it from the wall.
£65 posted.
120watt Behringer Lx1200h V-Ampire amp modelling head.
32 amp models, 15 cab simulations and 16 effects, such as delays, wah, chorus, reverb, etc. Runs 120w mono or 2 x 60w.
125 memory locations for patches.
Rear panel has many varying outputs for both live and studio work. Both jack and XLR outputs are available. Has Behringers Ultra G DI built in for plugging straight to a desk/recording setup. Cab sims can be switched off for live use. Supports MIDI controllers.
Has tuner, headphone socket and aux inputs.
Comes with 2 button footswitch.
More info here:
BEHRINGER: LX1200H
Marshall MG412 cabinet.
4 x 12 cabinet with 4 Celestion MG412 speakers. Smaller than a regular cab, easy to carry and light.
£180. Pickup only from Port Glasgow in Scotland.
