lower arms & tensions rods little problem
Ninocrack
hi there! a few weeks ago, I fit a the driftworks front lower arms, tension rods and de tein tie rods and ends. The car have now a very big angle when drift. I have 2 driftdays after this installs, and before every drift day I go to the garage and they put the front toe to 0 and -2 of negative camber and 8 of caster, and when I come back of the driftday the toe it´s very open and the camber seems bigger too, I put the wheels near 0 toe in my home and go again to the garage, I don´t know what can be the cause of this, so i will paste a couple of pictures and please tell me if in the garage they put everything ok after fix th geometries.
thanks a lot!!
Hi there. :)
In this pic...
Imageshack - b38057610kx8.jpg - Uploaded by ninocrack
You can see the locknut for the rosejoint is wound the wrong way! It needs to wind in, against the adjuster. How it is in the picture will allow movement and then the other adjuster will work loose, allowing the arm to lengthen! :( Make sure you tighten it properly before you drive the car, it's not safe how it is now!
