Is anyone on here into rc drifting ?
I have a really high spec one not doing anything and need to raise some money.
It took me a long time build this up to how good it is now, All it needs is a brushless motor and it would be epic.
The car started as a yokomo MR-4TC but now has a full RAYSPEED ultimate carbon conversion.( i dont think you will another on in the uk)
This is how it looks at the min but wont come with them wheels. (i spent alot of time and money getting them from japan lol )
There is alot off after market hop ups on this car to make it good
This is a bit of a list of the stuff on it. If anyone wants some info on it pm me. Im not sure on the price as its taken me a long time to build and sort out.
Front
Camber: -5
Toe:-1
Kick up: 0
Caster hubs: 4
Ride height: 9MM
Springs: YOKOMO DRIFT TI - SUPER SOFT
Trailing Steering Block: 0
Sway-Bar: 1.2
Shock Oil: 15W SCHUMACHER TEAM
Other: MODIFIED C-HUBS AND TRAILING STEERING BLOCK
Rear
Camber: -3
Toe: +3
Ride height: 6MM
Sway-Bar: NONE
Drive Train
Gearing: FINAL DRIVE IS 8.471
Front: YOKOMO BALL DIFF
Center: YOKOMO CARBON SHAFT
Rear: YOKOMO 1.5 COUNTER STEER SPOOL
Spar: 48DP - 72T
Pinion: 48DP - 20T
This is a pic with my new shell
Im sorry if i need to put a price but im just seeing if anyone one is intrested to start with.
Front
Camber: -5
Toe:-1
Kick up: 0
Caster hubs: 4
Ride height: 9MM
Sway-Bar: 1.2
Rear
Camber: -3
Toe: +3
Ride height: 6MM
Sway-Bar: NONE
Drive Train
Spar: 48DP - 72T
Pinion: 48DP - 20T
