SiiNerGia
Hello everyone! I'm having a lot of issues trying to set up my ebrake.
This is the second time I try setting it up and I can't quite get the power I need.
I'm trying to set it for drifting, so I need it to lock the tires while the car moves. Even though the stock brake doesn't have much force, I've seen people online using it just fine so it should be fine, however, I can't manage to get enough force to lock up the wheels while traveling at a straight line at around 15kph (10mph). it's pretty slow so I should have no issues, but I do
Things I have already done:
-I have a new set of rotors and brake pads
-I have set up the rear calipers to completely lock the wheels with 2 the ebrake at 2 clicks
-I have tightened the cable of the brake
Other info:
-My tires are small (165 14inch) so they shouldn't be an issue.
-Ebrake works fine when the car is stopped, it's just a matter of it not having enough force to lock the tires while moving
-Yes, I know getting a hydraulic would be the best thing to get what I need but I'm trying to make it work with the stock one, as it should
If anyone has any idea what else I could check I would really appreciate it.
Other info:
