Christoph_is
I'm about to invest in a IS200 which has a 'Mid Mount' turbo, has anyone had anything like this before?
Any good?
Any good?
Why would you do a mid mount turbo on an is200 when there is a shit ton of room in the engine bay, right next to the exhaust manifold?
The usual figure for 1GFE engines melting is above the 300 mark, which will be anywhere between 15-17 psi on an IS200 depending on how you've got it set up. Cooling is obviously going to make a bit of difference to how safe you can be at that power. If you haven't fitted a fuel return line already, it would be worth doing. The factory pump won't get you to 300hp so you will need to upgrade it anyway (if it's not done already).
