Mk1 mx5 with 1.8 VVT swap
DouglasB
I'm happy to send more information for any genuine interest.
Text me if you like. Not the best at checking this/messages. For some reason the instant email function doesn't work for my phone ha
07544347865
Basic spec:
MOT July 2016
Black
Shell has 70k
Registered as a 1.6 (114bhp) but has had a 90k 1.8 engine with VVT (146bhp) from a 2003 mx5
Welded diff
De-powered steering
5mm rack spacers
Hardtop with plastic rear window although this has a hole in it now covered with duct tape.
(Tyre delaminated and smacked the back window) no leaks.
Soft top is off the car but is included. Rear window has a taped up crack
Mk2 dash with mk1 centre console
Standard wheels
Minimal rust. Car can still be jacked on sills, there's is a £1 sized hole from where I removed rust to treat but that's it. Everything has been worked on so easy to work on in future.
Cobalt cat back exhaust
BAD POINTS
I did the wiring myself and there are a few things I didn't have the time/patience to complete which includes;
Electric windows don't work (just need wires connected up)
Indicators don't work. Everything is there and plugged in. Flasher relay needs replaced (£28)
Needs new head unit. As this is broke there is essentially nothing working on the dash. (£20?)
Car is painted with gloss and a roller but is a reasonable job as I'm pure amaze balls with a tin of Johnstones. Can't tell it's been painted this way until you rub your hand across it as there was no real prep work.
Windscreen has a crack in it
Make no mistake, the car is rough around the edges but it is solid and goes as gpod as a mk1 is gonna without a turbo. Would be ideal for someone looking to perfect it and turbo for an easy 250bhp. Skids very easily as is though.
Will come with lots of mk1/mk2 spares.
Bigger items...
1.8 gearbox is included
1.8 welded diff
Mk1 Glove box
Mk1 Dash
1.6 engine / interior looms
About 6-10 skid wheels
Interior can have carpet refitted.
£600
