Nardi centre ring.
cindral
Hi guys, just purchased a nardi classic from the shop. It arrived today. Just fitted the centre ring which only push mounts to two of the bolt heads via two gromets. Should there be two or six? As it seems a little flimsy.
Bolts in the two holes were rubber fittings are. Other four holes are empty.
Cheers
Ross
Hi Ross,
Yes it push mounts onto the 2 bolts.
Do you mean the ring is flimsy? It should be machined aluminum?
No just the way it's mounted to the wheel. I am using a snap off boss. Not tried the fat man test!
Cheers for clearing that up
Ross
