nardi
Dori Mat
Active Member
i'm not sure if it's me being a moron but the horn centre doesn't seem
to fit in the nardi steering wheel i just bought ?
i'm trying to fit it to the DW quick release steering spacer i already had
and the horn centre doesn't fit inside that :confused:
i also didn't get any sweets in my order :cry:
I had the exact same problem with mine of it not fitting the spacer,
I'm pretty sure I just punched the shit out of it to make it pop in!:smash::thumbs:
force was the next option just wanted to make sure it wasn't the wrong one or anything first :D
cheers dude :thumbs:
sure it wasnt just the metal contact thingys being stiff? had to squeeze the shite outa mine to fit it. damn worth it though, sexy wheel
The horn push clips into the boss, even the QR spacers have a little insert "thingy" that it should be possible to clip it into.
The idea is, it clips into the boss with the 'spring' design, which provides the earth contact, then the live connects to the pin on the horn push.
this seems to be the problem, the back of the horn push is bigger than
the hole in the spacer, is the insert removable ? i can see it has a gap in it
so if pulled together does it come out ?
failing this do the new QR spacers have a larger internal diameter ?
