Tony4 Member Nov 15, 2004 #1 I have just got my new koni spring and shock installed. The front passanger side is knocking BADLY.. any idea? my garage said he need to put in pads to cure it.. but need extra £140!!! please help
Tony4 Member Nov 15, 2004 #3 Mr2 MK2 rev1. Plus not to mention koni didn't supply the cap screws for the new shock to sit in the old shock sleve.
Y yeager Guest Nov 15, 2004 #4 Describe where the knock is coming from. Is it under accelleration, braking, cornering? You sure all the bolts are done up?
20vWill Active Member Nov 15, 2004 #5 Normally a loose/incorrectly fitted strut gland nut. They need to be feckin tight.
Tony4 Member Nov 15, 2004 #6 yeager said: Describe where the knock is coming from. Is it under accelleration, braking, cornering? You sure all the bolts are done up? Click to expand... knock when turning the steering and going over bump
R rotary_rogers Member Nov 16, 2004 #7 my bros vzr has done this for a while, we though it may have been the bearings due to the new forces applied to them by the new shocks.
