New LS Coilpacks - Custom Made Magnecor KV85 - Set of 6 - JZ - RB
dale_b
#DriftFactory
Yo dudes..
I got these LS2/LS3 Coilpacks about a year ago, also had the Magnecor KV85 leads made to suit. Was going to use them on my Altezza 1JZ, but I don't even own an engine at the moment, doesn't look like I'll be needing these for a long time..
Bought the Coilpacks from DynoTorque.. Also included is 6 connectors so you can wire them in.
The Magnecor KV85 leads have been made to relocate the Coils out the way of heat, they are made to mount the coils on or near the bulkhead. These have the new type of high temp spark plug boot, they also have a handy bit at the top to pull them from so you don't pull on the lead itself.
Why these coils??
They make massive sparks.. High boost blows spark out, these don't get blown out so easy..
They have built in Ignition Amplifiers (Coil On Plug or COP)(AKA Smart Coils), meaning you eliminate your old ropey Ign Amp..
These are a great upgrade for most high power set ups where you need a hench spark..
They will not work with OEM 1jz or 2jz ecu's.. Standalone ecu only.. (Due to Ignition Verification Signal(IGF) sent from OEM igniter to ecu, can not be replicated)
I believe they'll work with standard RB and SR ecu's because they don't have the same IGF signal.
Will work on just about any engine with standalone ecu..
This problem free Ignition system can be yours for just £395.
Delivery is £14 next day door to door courier. Collection from Guildford Surrey.
