Yes, yours will be 8/6.
You shouldn't have a problem with traction, how much power does the car have? What tyres are you using?
I think your key problem here is a) you have a Nissan, they have poor traction and b) you have a LOW Nissan, even worse... lol
This is why we have Geomaster hubs. We're just finishing manufacture of the first batch of V2 hubs with full S13 handbrake support, they'll be in stock in ~2 weeks.
keeping on the same lines as the original post can you tell me if the new version of the hsd allow for a higher ride height than the old ones (V1)? Its just that ever since fitting the dw geomaster hub knuckles to the rear of my s15 i've had the bottom platform wound to the max and even made spacers to the damper and top strut to get some added ride height bit its still literially on the floor!
Neat, please send me a PM with someone who sells 5stud conversions.
Hi Al,
Kam's info is a bit out of date actually, we've revised all the kits to have longer rear bottom brackets to work with the hubs, sorry you've had to go through the hassle but now they're 100% compatible. Plus you can go mega high on a standard car if stock ride height is your thing...
Give Garage-D a call for 5 stud parts... +44 (0)1923 251588
How much longer has the bottom brackets been made? Can you supply these seperate? Can you also supply 5 mm/kg springs for the rear? save me buying a whole new set of coilover, altough i would like some shiny new one but monies get spent elseswhere on the car at the moment but i need to address this issue.
Thanks man. Am I going to have a problem with my "old" HDS's and the knuckles? I want the car low and nice but not max out the lower threads/mount.
Is it possible to get the GTR-D in 17" or any other cool wheel with a deep dish?
