hi, I've got for sale a newly reconditioned engine build, it is still being worked on, so it is not ready yet, i got the job going but run out of funds to finish the build, so selling the build for only £1800
for that you get a fully skimmed and resurfaced head and block, with hks head gasket 2.0mm, with arp head bolts and acl bearings. it also come with brand new tappets (all 8), new rocker arms and valves re seated and brand new timing belt. new oil pump, water pump, oil pressure switch, eagle H beam con rods, and all new gaskets all over. it literally is a brand new engine worthy of running easily 1.4 bar of boost without any issues, it will come with 6month warrantee , and will need to be run in in properly and serviced regularly. you can get extra work done at half the cost, i.e. oversized pistons 0.5 - 1.0 wiseco from only an extra £400. can also add cams and titanium springs at extra cost.
parts alone are worth around £1600 and you get the labour and actually engine for £200 on top. will last for atleast another 80,000 miles
give me your offers and we'll see what we can get done...
thanks for looking
thanks for looking
