Ian Baldwin
Nissan Skyline R33 GTS-T - 75,010 miles. 1994 Spec 1 Model.
(Is actually 14K less than clocks read as on import changed from Kph to Mph, all documented)
Pride and joy can't believe I'm advertising really, but saving for a boring adult mortgage.
Highlights are that it's RB25DET was mapped by Greg Gush of Protuner to 450bhp with 415lbs/ft at 1.2 Bar, low mount HKS GT2835 Kai turbo, Link G4+ ECU, HKS NTK wideband equipped lambda module with full active knock control, able to retard timing in the event of knock. Splitfire Coils and Defi gauges. HKS Turbo Elbow, Pro Tuner Decat with HKS Cat Silencer with full HKS Hi-Power Exhaust.
Fully forged Speedtek gearbox with billet aluminium plate, Competition S4 Clutch Kit, short shifter kit, Nismo Braided Clutch hose and Nismo N1 Water Pump.
Alcon Front Calipers and discs with Pagid RS29 pads and braided lines. Driftworks Coilovers, front tension arms, Front Upper camber arms, rear camber arms, fully poly bushed with Hicas lock out bar. Rare Ultralite Nurburgring 18" Wheels, Apex Roll cage, stripped front seats back with Recaro buckets with NG 6 point harnesses.
The lack of ABS or any driver aids and the sheer response and feedback it offers are superb. Originally was an auto but converted to manual so has the 4.36 Final Drive Rear Viscous LSD Diff (geared for acceleration). Making it feel over 550bhp!
2 previous owners since import from Japan to the UK in 2005, the last owner before me had her for 10 years (Nito, Forum member). All mods with prices and date fitted on a spreadsheet. Its very tidy, with no rust, always commented on for how stunning it is.
You will struggle to find such a well looked after and clean GTS-T in the UK with so much spent on it, which is reflected in the price.
There is a substantial and thoughtful specification applied to this, along with a lot of time and money lavished on this and it has the best of everything. Full Spec as follows:
Engine
RB25DET (449.2HP/415lbs/ft at 1.2bar boost)
Fuchs Titan Race Pro S 10W50 Oil
NGK Iridium IX Spark plugs
Splitfire coil packs
HKS GT2835 Kai Sports Turbine Kit
HKS Stainless Steel Turbo Elbow
Pro Tuner Decat – Now HKS Cat Silencer
HKS Stainless Steel Front Pipe
HKS Hi-Power Exhaust System
HKS Adjustable Actuator
HKS reloaded induction kit
HKS SSQV Blow Off Valve
HKS 550cc Yellow Top Injectors
Link G4+ Engine Management system (ECU)
Walbro uprated fuel pump
HKS Hybrid Sports Oil Filter
Bells Custom Catch Can and washer fluid holder
New exhaust manifold gasket and studs
Electronics and Management
HKS EVC 5 Boost Controller
HKS A/F Knock Amp
NTK Wideband Lambda Sensor with Syvecs ready plug and harness
Field Harness Extension
Defi Control Unit
Defi 52mm Black Boost Pressure
Defi 52mm Black Oil Pressure
Defi 52mm Black Oil Temp
Defi 52mm Black Water Temp
Defi 52mm Black EGT
Defi 52mm Black Fuel Pressure
Defi Link Display Unit
Defi Tacho pulse Sensor Set
Defi Speed pulse Sensor Set
Excelvan LCD Wireless TPMS (Tire Pressure Monitoring System)
Optima Yellow Top Battery
Chassis
Driftworks Coilover Suspension
Driftworks front tension arms
Driftworks Front Upper camber arms
Driftworks rear camber arms
Rear Sub frame polyurethane bush kit
Steering rack polyurethane bushes
Japspeed Hicas lock out bar
Japspeed front strut brace
Japspeed rear strut brace
Alcon ADex Calipers x2 F
Alcon 343mm Discs x2 F
Pagid RS29 x2 F
Standard Nissan Calipers x2 R
MTEC 295mm C-Hook Discs x2 R
EBC Yellow Stuff, oversized pads x2 R
Motul factory racing DOTR5.1+ fluid
Driftworks Braided Brake Lines all round
Ultralight Nurburgring 18" x 9.5" ET20 deep dish wheels F+R (Alloys)
Toyo R888R tyres 235/40/18 Front
Toyo R888R tyres 265/35/18 Rear
15mm Superforma Hubcentric Spacers Front
Wheel arches rolled and flared F (15mm) + R (8mm)
4 Wheel Track Geo alignment and corner weighting
Cooling
Apex Performance Front Mount Intercooler
Mishimoto Aluminium Large Capacity Radiator
Mocal 19 row Oil Cooler Kit
Nismo N1 Water Pump
Blitz Sensor Adapter Sandwich plate
Samco Silicone Coolant Hoses (blue)
JDM Garage Water Temp adapter T piece
Pro Tuner Fuel sensor fitting
Transmission
Standard R33 5sp manual box housing
Forged Speedtek gearset internals with bearings and seals,
Billet Aluminium Plate
Competition Stage 4 Clutch Kit with machined flywheel
Japspeed short shifter kit
Interior & Safety
Apex Performance 6 point FIA approved full roll cage plus padding
Recaro Furious Pole Position FIA approved Side Mount Bucket Seats (driver and passenger), rear seats removed (TOTAL seats 2)
NG FIA approved Black 6 point harnesses (driver and passenger)
Works Bell Rapfix II Quick Release Steering
Nitosport Gearchanger
Momo Race 350mm Steering Wheel
HKB Steering Boss
Driftworks (driver) and Bride double locking Adjustable Seat Rail
Momo Leather Handbrake
Fabricated aluminium door panels/quarters and rear panel
Nissan R34 GTR Din Pocket
Carbon Trim Dash Covering
Fire extinguisher
Interior stripped out rear and roof lining
Red Arming Switch (Map change when cat equipped)
BL Optronics 200 degree Green LED's to Combination Meter
Air Con removed
Exterior & Dress Up
Undersealed Car in Black
Vehicle Colour ‘NANBU BLACK’ (CODE: PROTON 64113969)
Nismo Clear Side Repeaters
Customised front bumper
Custom Front Number Plate Bracket
NG 2" Black Harness webbing Door Pulls
HID Main Beam Headlight Conversion
Genuine Nissan R33 GTR Spoiler and bootlid
Rear Wiper delete
Private Plate – K333 UUP
Ice & Security
Toad Cat 1 Alarm
JBL Door Speaker
Only things to note:
Front window seal could do with replacing as it's come loose on the top O/S slightly. There are some stone chips on the bonnet and roof but it is a 24 year old vehicle so to be expected. There really isn't anything else to note, it speaks for itself.
Any questions please ask.
0742760 2252
£25,000
Engine
HKS A/F Knock Amp
Defi Control Unit
Defi 52mm Black EGT
Chassis
Pagid RS29 x2 F
Cooling
Nismo N1 Water Pump
Transmission
Interior & Safety
HKB Steering Boss
Fire extinguisher
Air Con removed
Exterior & Dress Up
Rear Wiper delete
Ice & Security
Toad Cat 1 Alarm
JBL Door Speaker
0742760 2252
£25,000
