Sparcoxs
Hi,
I have for sale an SR16Ve engine that has already been converted onto a RWD SR20Det block.
Built and put together by Lebdwith Racing over in Ireland. Full build with all new genuine Nissan bearings & mating the FWD VVL head to the RWD SR20Det block with all required machining work
Block bored to 87mm
CP Pistons
1600cc VVL crank
1600 VVL rods
Standard Valve Train
VZR cams
Metal head gasket
New VVL water pump
G-Spec adjustable cam gears
Mazworx solenoid re-location kit
Mazworx RWD VVL Oil pump
Jenvey Throttle bodies with filter,injectors (requirse inlet manifold)
Also have the standard injection system sitting in the shed as well as an S14 gearbox.
All built using Mazworx & G-Spec components for the RWD conversion.
Was initially to convert an Escort for stage rallying but project dragged on and storage became an issue for the shell. Many brand new components imported from America for the RWD conversion as well as bearings,rings,water pump, lightweight pulleys, gaskets, pistons etc Sadly time has seen my project go on forever and desire to complete it has gone & shell sold. Any reasonable offers welcome.
£5000 o.n.o
Thanks, Rob
Block bored to 87mm
CP Pistons
1600cc VVL crank
1600 VVL rods
VZR cams
Metal head gasket
New VVL water pump
£5000 o.n.o
Thanks, Rob
