Offset Subframe bushings
TriniGT
Do you'll offer offset subframe bushings? I have an S15 that I want to mount an R33 GTR rear subframe with the diff and bigger brakes to the back of my car. Has anyone done this and do you'll offer these offset bushings? I am ordering the full suspension kit and if this can be replace the regular solid subframe ones that would be great. The difference in distance between the S15 bolt points and the GTR subframe is about 0.5cm, but I didn't want to force the frame on and have distorted bushings.
Help me :dw:.
Thanks I spoke with Ben and I am doing a similar setup to my rear end like that in the S15 you'll got, I will be ordering the Pro handling kit and I may be lucky enough to get a better condition S15 rear subframe as mine is buggered from a dumb idea I had, more like a brain fart :(.
