oil filter relocation prob
white car
The o ring on one of the 90 degree joints has perished after only 1k. [aeroquip 90 degree adapters.] which made a nice puddle on my drive:smash:
So I need to buy a new joint will you be able to tell me sizes etc so I can order a new one?
regards
lewis
did you put oil on the oring when you installed it mate ? or did you tighten it up dry, if you did it dry it will have ripped the oring mate.
you can get the orings from anywere, next time oil it :)
Have you got a picture to explain what you're after?
The 90deg joiners don't have any O-rings in em you see....
I jumped to the conclution he ment the oring under the fitting adapter and not the actual 90Degree fitting,
*gets coat and runs for the hills*
when looking at you relocation kit pic in your shop its pissing from where the blue bit meets the red bit. I just presumed there was a o ring there.
