Option S13 Update!
Option_S13
Here we go....
* MOTEC M4 Engine Management SOLD!
* Recaro SP-G Seats SOLD!
* Seating Rails SOLD!
* GTR 34 Fr. Carlipers & Apexi 330mm plates SOLD!
* GTR 33 Rear Carlipers & plates SOLD!
* Option Radiator & Electric Fan SOLD!
* 1998 180sx Rear lenses SOLD!
* Front & Rear Cusco strut braces SOLD!
* Willans four-point harnesses SOLD!
* Sparco St/Wheel SOLD!
* Oil catch tank SOLD!
* Front cooling plate SOLD!
* Blow-off valve SOLD!
* Fuel Pump SOLD!
* Option Headlight Air-duct SOLD!
* Option Crystal headlight lenses SOLD!
* Veilside side mirrors SOLD!
* Nismo clear front indicator & side mirrors SOLD!
* Nismo Gear knob SOLD!
* Drift Hand-brake SOLD!
* HKS Hyper Max D(Drift) Suspension (6 months old) SOLD!
* Cusco Type-RS Limited Slip Differential (in housing) SOLD!
* Optione Vented carbon fibre bonnet SOLD!
* Cusco Rear adjustable upper arm +
Cusco adjustable Rear toe-rod SOLD!
* HKS EVC boost controller SOLD!
* HKS Oil temp, Exhaust temp & Oil pressure gauges SOLD!
* Engine (spec below) including Blitz Air filter: 2,300 GBP
* Cusco Roll Cage 450 GBP
* HKS Hyper Exhaust 250 GBP
* Dspeed Maniflow 500 GBP
* Apexi GT front mount Intercooler & Pipings 550 GBP
* HKS Oil Cooler kits 400 GBP
* Cusco Tension rod 70 GBP
* Top Secret Front bumper (Genuine) 450 GBP
* Momo carbon fibre trim steering wheel 50 GBP
* C'S Quick shift mechanism 100 GBP
* Apexi boost gauge 30 GBP
* ANYTHING ELSE YOU CAN THINK OF??? Please e-mail me your offer!
Contact me at: gern13@yahoo.com
Engine spec: Nissan CA 1.9, JE 86.5 mm pistons, Tomei conrods, HKS 264 degree cams, HKS pulleys, Tomei head gasket, HKS 555 injectors, Blitz air filter. (400+ Bhp no problem!)
Thanks
Itti
sammysideways said:
so what do cusco tension rods do?? any improvement??
Any play in the tension rods will change your wheelbase amongst other things making it harder to keep a steady drift going.
Ueo san says in a dori-ten video that apart from the dampers and springs, this is one of the first things you should change for a 86. I'm sure the same applies for a silvia because I was talking to the guys from Tein UK at the Autosport show and they said that for a silvia the most important parts to change for drift use are the dampers springs and tension rods.
conclusion: GET SOME
