PS13 Not starting.
Westyyy
Hi, I am having some issues with my SR20 DET PS13.
Original i had an issue with the fuel pump not getting power and working. After setting up an external relay the fuel pump now works correctly however the engine still does not start. I am not getting any spark and also injectors are not firing. I believe this could be an ECU issue however any help would be greatly appreciated.
Thank you.
Not got a knackered old anti-theft alarm/immobiliser fitted has it? They love to cause issues like this.
Thank you for the help however The car isn't fitted with a alarm or immobiliser as i have seen around that this could be the issue as well.
Did the front wheel rub through the wires in the wheel arch by any chance. Realistically that loom has probably been moved in every S-Chassis at this stage
