BeckmannVidal
Cheers -
Do the Geomaster 2/3 rear knuckles correct both the angle of the control arms AND the angle of the axles for S13? Currently, the axles and the rear upper control arms rub/hit the frame in the rear - even w/ solid subframe risers
I run standard stock 6-bolt s13 axles and stock s13 rear calipers - will the knuckles work with this setup?
Do the knuckles retain the same position of the rear hubs? (asking for wheel fitment purposes)
I know these knuckles won't magically fix the awful "slammed car" setup I have, but I'm hoping they'll help! PBM's 25mm of correction doesn't look like it'll be enough when Driftworks offers twice the correction.
Thanks!
Thanks!
