RikGTT
Hi, just a question on the correct way to go about re-fitting the shifter housing back onto the R154 case? I took it off to have the shifter extended for my swap and when putting it back on the shift and select lever is catching an wasn't sure how to go about getting it seated back on the shaft. What's easiest way??
Here's some pics of the bit I'm on about:
Cheers!
Cheers!
