sidewaysman
well the time has come, lost full motivation in the car after the engine failed.
car will be being broken for parts at the end of July 2021 (currently away with work). Any pictures wanted or enquiries fire me a message.
A comprehensive list below.
Bare Shell, no panels with glass, Passenger door shut replaced (due to damage caused at Anglesey)
Front tubbed. rear tubbed. All rust repaired 2 years ago
£1500
Dmax 30mm front wings £300
TH components rear quarters £200
Zero G wing £200
BN sports front bumper, side skirts and rear bumper. 400
Rear bumper bar with jacking point welded on £150
eBay side splitters £30
Origin bonnet £250
N1 headlights £600
GK tech mirrors £50
Doors with glass and motor £100 each
Nismo style front braced tension rod brackets £200
GK tech front drop knuckles drilled out for 350z brembos £450
Japspeed kinked tension rods £100
25mm extended lower arms £100
Nissan Maxima steering arms £30
Steering rack moved 25mm £100
S13 rear subframe £50
Rear geomaster 2’s modified for 350z brembos £250
Rear Adjustable toe arms £50
Rear camber arms £50
Rear traction arm £50
Japspeed kinked front tension rods £100
Front camber arms £100
Cusco brake stopper £50
Rear LED lights £150
4.3 diff with 5x1 shafts. Drive shaft spacers. £450
Rear white line anti rollbar £50
350z front and rear brembo brakes £700
stock handbrake mech £150
Meister R coil overs £600
Intensive hank wheels £1800
18x10 et minus 5 front - 225/35/18 nankang NS2R, 18x12 et minus 10 rear - 265/35/18 Zestino
6 point bolt in cage from fabricage with cross door bars £500
Sparco circuit drivers seat, driftworks rail £300
Sparco driver passenger seat, homemade rail £250
Boost gauge £50
water temp gauge £20
AEM AFR gauge £100
Battery box £20
Plumb extinguisher £100
Full carpet, not mint £100
Half cut door cards (offers)
Willans harness x2 £150
Dash cut for cage £200
Centre vent £100
2 sets of Clocks £100 each
ENGINE HAD BOTTOM END FAILURE
Link ECU £1400
Walbro 440 in tank pump £80
R32/s13 fuel tank £150
740 injectors £200
Greddy inlet £100
S14 throttle cable £50
Q45 throttle body £300
R8 coil packs with loom £250
Japspeed alloy radiator £100
Power steering cooler £20
3mm steam pipe T3 exhaust manifold with 45mm vband for wastegate £300
Pulsar GTX 3076R £500
Braided oil and water lines £100
45mm turbo smart wastegate £350
RB25DET gearbox with OS giken 1,2,3 and hardened input shaft £3000
OS giken twin plate clutch £300
Braided clutch line £20
S13 master cylinder £50
Uprated master cylinder £50
Front mount intercooler £50
Intercooler pipes to suit current setup £50
GTR bumper bar (washers welded on to support intercooler) £400
87mm wiseco pistons £500
Stock cams £150
AN rocker cover fittings £10
Catch can with braided lines £10
2 sets of Cam covers £50 a set
Spares
Origin bonnet £100
2 sets of N1 headlights. 1 headlight has broken glass £1200
25mm extended front lower arms powder coated £100
Rear lower arms powder coated £50
Pair of drive shafts £250 (4 sets)
3/4 sets of rear lights in various conditions £100
Boot £100
Zero G Boot spoiler £150
2 steering racks £200
3/4 rear bearings £30 each
2 tins of paint (body)
26 zestinos (hard compound) £80 each
Pair of door cards £150
Rear subframe £100
Rear knuckles with handbrake mechanism £150
Standard inlet £20
R32 Tension rod brackets £50
3 pairs of standard front lower arms £80 pair
4 pairs of standard rear lower arms £80 pair
Brand new N1 oil pump brand new £250
Brand new Crank collar brand new £70
Brand new Full set of bottom end bearings brand new £200
Probably a few things I have forgotten like looms and heaters but if you need something I probably have it.
