Hey guys I'm having a problem with my 1993 nissan skyline gtst. It's a overheating/ low oil pressure problem. Here current mods
Turbo back exhaust
Front mount inter cooler
Boost controller
Z32 maf
550cc injectors
Engine is tuned to run 14psi
So here's the problem. I can drive the car just fine when engine is cold than it take a while to warm up. The temperature rises quick, even to a boilover. The oil pressure will drop so low that the engine stops if at an idle, however if there are about 2000 or greater rpms it will stay running.
I tried using thicker oil and changed t-stat but neither helped the problem.
Any help is appreciated. Thanks!
Turbo back exhaust
Boost controller
Z32 maf
550cc injectors
