RB25det gearbox to SR
kiwi-dave
sup peeps,
Basically my clutch pedal on my ps13 sits really high (couple inches higher than brake pedal)
If I adjust it to match there isn't enough throw to engage the clutch
Its running an OS Giken twin plate sr clutch which has loads of life in it
What release bearing/ sleeve should be used sr or rb? could the wrong ones be causing the issue?
TIA
Isn't the OS giken a quite agressive clutch aka high grabbing point ?
RB25/VG30 box have the same release bearing/sleeve
Not to the point that the clutch pedal needs to sit this high
