Question:
[Green] Rear lower arm bush.
4 required when using standard lower arms.
None required when using Driftworks lower arms.
[Orange] Upright and control arm bush.
10 required with all standard control arms.
6 required when used with a Driftworks Four Arm kit.
HICAS equiped cars require 2 less ‘upright and control arm’ bushes.
The Green I understand, you wouldn't need any bushes if you use the lower arm. But, as for the Orange, if I look at the picture and you have:
-Total Hicas Eliminator
-Driftworks Rear Camber arms
-Driftworks Traction Control arm
Do you then still need these bushes? If you do it's 4 (1 for camber arm, 1 for TC arm, 2 sides = (1+1)*2=4). I'm confused...
