royal
S1- F.T break!
Do you guys have a picture showing the rear arm setup? I've got a 5 stud conversion if that changes anything (presume thats just the hub?). I've broke the most rear lower arm (not the triangular one, the one that is a single arm to the very rear). I've also popped the drive shaft out of the hub where the boot is. Not sure if thats supposed to happen?! To top it off I've also knackered the front subframe that I've only fitted 2wks ago If it makes you feel any better the DW front arms are fucking nails and not damaged at all!! I'll get some phots in the morning.
