Rear Bush
Emil
Active Member
Do the bushes that you sell,fit in the rear HICAS arm?
I'm on about the bit that goes from the Hicas arm onto the suspension i think
Nope, hicas uses balljoints on the hub end (where there'd be a bush on non-hicas cars), no bushes to be replaced.
thanks anyway,quick question,the elbow that i had from you guys,it fits fine and everything,just got a blow from around the lambda sensor? anyway i can fix it?
