Hooooooooow much . I think that must be for PDF01114SS which is the complete kit including wire to control box. Can you get PDF01103S, which is just the sensor & fitting nuts?James said:Yup, there's stock of those in the warehouse, so can be with you in 2 days if you order before 12.
They're £102.25 inc the vat though
sadly not.....Barky said:Hooooooooow much . I think that must be for PDF01114SS which is the complete kit including wire to control box. Can you get PDF01103S, which is just the sensor & fitting nuts?
James said:sadly not.....
PDF01114SS is £125.73
The spare Defi sensors vary a lot in price....
oil/water temp sensors are £34
oil/boost pressure sensors are £92
EGT sensors are £102
all those prices are without any wires or extra gubbins too
