cefiro_drifta Mad pointing Munky Sep 7, 2007 #1 when u gonna have them in stock as i want some as the new turbo is makign em hit the limiter very VERY quickly
james Administrator Staff member Sep 7, 2007 #2 doh..... loads in stock here, just updated the web shop for the correct stock
cefiro_drifta Mad pointing Munky Sep 7, 2007 #3 also james .. your mocal sandwic plate, does it have a take off or is it just the outlets for an oil cooler ?
james Administrator Staff member Sep 7, 2007 #4 the mocal ones don't have takeoffs for gauges, none of the thermostatic ones do apart from the real posh greddy ones
cefiro_drifta Mad pointing Munky Sep 9, 2007 #7 mitch - these easy to fit ? james - am i correct in saying that these dont need to be modded to fit a redtop sr ???
Mitch In moderation Sep 9, 2007 #8 Fairly straightforward bolt on for redtops, and a little cutting of the rocker cover for the blacktops.
S sammysideways Active Member Sep 9, 2007 #9 check the bolts as they come out, if they look thin/stretched then replace them. i snapped one in the head, was a pain
cefiro_drifta Mad pointing Munky Sep 9, 2007 #10 so i recon i should look in to some replacement bolts while its off ... james can u get these ?
S sammysideways Active Member Sep 10, 2007 #11 nah just check them, know people that have fitted them fine, also know people including me where they have snapped. dont think its a issue if engine hasnt been fiddled with much
