rocker arm stoppers.
kieran_e1
In need of practice
I've bought and received the rocker arm stoppers from the shop. opened them up and they have a slight bend at one end.
will these fit a red top sr?? ( i know i should've asked beore ordering but the thought of a freee wham bar distorted my judgement)
They're designed around red tops. :)
When you say a bend, do you mean they're damaged??
erm, i dunno , both of them bend at the end slightly to the same degree but the bend is side to side not top to bottom if that makes sense. it's more of a sgallow arc than a bend
hmm it seems it's only on one side too
pic
Just looks like it's a bit bent yep, easily done when removing it from the bubble wrap or whatever! It'll sit flat as soon as you bolt it up! :)
