rota's in 5x120
bell
Without patience
howdy people of d.w
do rota intend to let us 5x120 people into the loop of coolish wheels?
i'm swayying towards some grid drifts for my e36 but really dont want the added expense of pcd converters.
could they be specially drilled at all?
cheers
Id like some rotas in e39 fitment aswell, preferably the gtr ds. if you cant do e39 centre bore at least do bmw fitment as i want them but dont want to rub hub adapters
Bell the only rotas in bm fitment are 17" and 18"
Grids and torques
Can't see them doing the 16s for how few people buy 16" aftermarket wheels for bmws.
Grids and torques
Unfortunately it's true. Mike is spot on. Smallest available in 5x120 fitment is a 17x8.
not in 16x8 they dont, and thats going by your link ;) i dont want 17's tires are to dear especially the ad08's i choose to run
Makes no sense??? Unless you are running smaller width on the 16s then the 16" AD08 is more expensive. Even if you do go smaller, the difference is basically nothing. 225/45/17 is a great size to run when it comes to availability and pricing. 16" is pretty uncommon.
ste what would be the costs entailed in getting a set in 5x120? surely its a case of drill them in 5x120 which they do in 17's anyway?
mike i know but i prefer 16's man ;(
clark3y really i have a good contact that uses the 16's for 1 track day then sells the tires and he uses 16's i dont think 100quid for a pair of 16inch ad08's is badly priced with 7mm of tread on them as appose to 115 for one tyre in 17inch flavour. coupled to which I DONT WANT 17's been there really dont want them on this car as it accelerates perfectly fine the way i have it.
Hello bell, unfortunately Rota don't do custom orders. Regardless of cost. As mentioned above, the 16" option in 5x120 is such a rare request that it just isn't financially viable for Rota to produce them. I'm sure there are certain companies that can change the PCD for you (or there is the PCD adaptor route). But by the time you've spent the extra, you could have had a set of 17's which are readily available. Sorry :(
