RPS Max Street for RB20/25DET Skyline £269!!!!!!
Bon Bon
It'll be fine
Hi guys,
This is just a one off deal, single RPS Max Street for RB20/25DET that we've got left on the shelf from when we stocked RPS clutches.
Just to clear it we're doing it at £40 discount, so £269!! Ready to go so could have it out to you for next day delivery.
First come, first serve!! :thumbs:
Do you still have this? It's a full face clutch right? Oh, and can it be sent to the Netherlands? This might be just what I'm looking for...
Out of interest, what would it cost to add a light weight flywheel? And that would probably make shipping dearer?
Lots of questions, sorry :P
Yep, yep full face organic, and yep it can be sent to the Netherlands for £25 delivery. :)
RB flywheels aren't in stock at the moment I'm afraid BUT if you wanted to order I don't mind doing you the combined price now and sending it out later when they come in (about 8 weeks). I could do the flywheel for the package price of £250 when purchased with the clutch, and still do the single shipping price since stock is our issue. :thumbs: That would put it at £544 delivered for the lot, or £294 delivered for just the clutch!
D'oh I completely forgot about something... The RPS is just the clutch right? I'd still need a pressure plate or use the stock Nissan one, correct? :rolleyes:
Really? Hmmm, ok... :cool:
Let me get back to you :)
edit: oh yeah, how much lighter are the flywheels? :rolleyes:
Yep!! It's about normal for lightweight flywheels, makes a big difference to the response. Huge improvement, my 1JZ is fantastic with one of our lightweight flywheels fitted, standard VS lightweight is really noticable.
OK new development... I was over at DBM Engineering to help with passing my MOT (which I did but I got pulled over by the bacon squad on the way over because of that same MOT and let's say I lost half the saved up money for parts). In the end I have my MOT though.
Anyway, DBM said I need tie rod ends for both the front and back (damn Hicas) plus a lock bar...
So, can you guys tell me what the grand total would be of...
- RPS Max street GBP269
- tie rod ends front GBP???
- tie rod ends back GBP???
- Hicas lock bar GBP???
- shipping to Netherlands of all parts
I'll have to put the flywheel on hold, unless the piggies decide they won't fine me, which I doubt. And by the time they decide if they will or not we'll be 8 weeks down the road hehe.
Also, if there are any parts which you would recommend I change at the same time as above list, please tell me as I might as well just get this over with now before I get in even bigger trouble.
RPS Max street is gone I'm afraid.
Tein tie rods and ends are £141
What car do you need the lock bar for? We have the R32 and S13 hicas lock bars, but not R33 or S14.
Shipping on everything will be calculated when you go to check out in the webshop :thumbs:
For HCR32 if you need just rod ends you can buy the Tein rod ends alone for £70.50, the Hicas bars we have will work for your car, and we can do a Spec clutch & flywheel at a discounted combination price. :) Shipping to the Netherlands is no problem either, should be £25 on the online shop!
Bumpety, was a bit quiet because I lost a lot of money on fines...
Got some more now, and still need a new clutch, my Hicas still has massive amounts of play, and my car needs a tune up :)
So I have a little shopping list, and what can you guys do for me :p
- Engine oil + filter change ( I still have ~2 liters of Silkolene Pro)
- Spark plugs
- Clutch + upr pressure plate
- Flywheel, would I really need one or not (95% street use)
- Total Hicas eliminator maybe now? Then I wouldn't need the separate tie rods anymore right?
Are there any mods around the rear suspension and transmission that you normally never get around to but might as well do when you're doing clutch/hicas stuff?
I found an ORC clutch kit including flywheel for ~800gbp and that's the price I'm trying to beat. Everybody says I'm stupid if I went for that :wack:
FYI I drive an RB20det powered R32 :)
