S13 3 cylinders
Foodeat199
Hi guys, first of all sry about my bad English.
I recently bought an s13 89 and I already had to remove the head "joint" and it was running like a clock, yesterday I was running like 230/240 on the highway and suddenly my s13 lost a lots of power, and start to work on 3 cylinders, when I arrive home I remove the ignition plugs and one of them was melted, I bought a new set of iridium plugs NGK recommended for the engine, try to start and again 3 cylinders, I had 12 volts on the injectors, and I have spark on the plugs, I don't have anything to do the compression test, and I dont know if had signal on the injectors, the car don't have any type of bad signals like white smoke etc so I think its not a puncture piston, I'm without ideas, need help please!!
Thanks André
Check the drop resister silver box under the air filter it should be that faulty if anything.
Sent from my B1-810 using Tapatalk
