S13 hubs onto S14
Rhys w
Have some S13 front 5 stud hubs that have popped up for sale, it comes with full knuckle, hub/wheel bearings, brakes etc. Wanting to put them on an S14, reading all sorts of different things online. From what I gather, I'll need smaller shock bolts or possibly just s13 struts. And S13 ball joints pressed into my S14 LCAs. Is that correct? Only talking about the front setup.
S13's didn't come in 5 stud, so you'll already have some mish-mash of stuff going on.
It might just be a full S14 setup?
S13 knuckle to shock bolts are 12mm diameter where as the s14 bolts are 14mm, and you're right the LCA ball joint tapers are different, s13 and s14 ball joints both fit in to the same size hole on the LCA so are interchangeable.
