S13 rb25det neo
sirmaiz
Runs and drives, need proper tune and color refurbishing (faded out color, looks pink) since rebuild has about 100metres on it!
Rb25det neo full rebuild, VEMS v3, rb25de gearbox, 680cc bosch injectors e85, aem e85 fuel pump, new n1 oil pump, water pump, acl bearings std size, oem gaskets set, oem timing belt set,
oem piston rings, refurbished head, oil cooler with thermostat, upgraded radiator, greedy style inlet, 80mm throttle body, top mount, gt35 turbo, turbosmart 48mm waste-gate, custom exhaust, s14 brakes refurbished powder coated, brembo rotors, HEL brake lines, new fuel/brake coper lines, 5 stud kit, hsd coilovers, poly bushings,
all control arms etc. powder coated, rust free chassis, wheel adapters to 5x120, german shaper 9,5j and 10,5j wheels,
maxda rx7 seats, depo gauges.
This set up should be good and safe for around 400whp
10k eur (partial payment can be e36 or e46 touring/sedan 6cyl)
kristaps@933.lv +371 286474_44
Still working on car, so price will go up, once will do engine brake-in, get proper tune and paint job.
