S13/S14 Adjustable front lower arms technical info
Lukey13
Active Member
Okay, basically I have a S13/PS13 with a full 5 stud conversion using I believe:
S14 5 stud rear hubs on S13 rear lower arms
S14 5 stud front hubs on S14 front knuckle and lower arms
(also S14 front brake set-up)
I am thinking of buying adjustable front and rear lower arms set for my car as I already have the rest of the adjustable arms fitted and would like to get the best from the set-up and ditch the last of the standard bushes.
So my questions are:
Are the front lower balljoints different?
If so do I need to order adjustable S14 front lower arms?
Are the rear balljoints the same between S13 and S14?
If so then I need to order S13 rear lower arms, is this correct?
Any help on this will be greatly appreciated!
Cheers :thumbs:
Yes, they are different (ball joint taper).
But, our lower arms come with both fittings, so you will be fine :)
