S13 sr20det (non-running)
BabyBhp
Hi everyone
Ive lost my patience with this car and cant be asked with it. the sr20det is fitted and everything, engine turns and fuels getting in however its not getting spark. im not much of a electrician so i dont even no where to start with the thing.
the engine was standard from previouse owner done only 60k. the shell and body are fine may come across the odd tiny rust spots, othere then that its quite sweet.
the car will come with extras such as:
3'' exhaust system
induction kit
fmic
apex springs
boost gauge
pics can be found here:
http://www.driftworks.com/forum/showthread.php?t=8452
need quick sale so im only asking £1900
thanks
Yasir
could be a nice running car, but IMHO 1900 squids for a none running car.... No chance...
it would be worth your while to make it work and spend the money, then it would be worth it!!
but good luck with the sale mate...
the question is who do i give it 2, 2 make it work?
i thought £1900 would be ok because the engine and running gear cost £1000 on it self
well if thats the case, remove it and sell it on as seperate....
It may be 1000 but in a car, its the car that take the price, not the parts on it..
I would gladly come and look at it for you for a small fee..
Thanks
Is it an S14 derived SR or an S13 SR? also what have you done with the wiring? is it an S14 loom made to fit the S13 body harness
~and~
If I come and fix it can I have the FMIC? :D
mark- yhpm
nissanboy- if you fix it i could give you some money
mad cas- yep the engine is from a s14, and ive used the s14 loom. and yeh if you fix it you can have the fmic i dont mind using wmic if its running
