s13 with a rb20det gear issues
boriss
i have a 200sx with an rb20det
after a quick burst in the s13 i loose clutch peddle and cant put it into gear, If i force it into gear it will then shift fine and not a problem but then if i blast it again it will do it again
now when im driving normally just cruising it will now do it, It had done it twice on me but on the 3rd time it wouldnt go into gear at all. For a good 20mins of forcing it back into gear to get out of a sticky situation it finally when into gear but now its hard to get into gear all the time and grinds into reverse
also if i turn it off when it has happend and put it into gear with the clutch in and try and start it it start to jolt forward
any ideas
thanks in advance.
