S14 CS2 coilover spring height?
Hi guys,
Might be a stupid question but can someone explain please.
The choice of spring height on the s14 CS2 coilovers....what will this effect? Just the height the car will go down to?
I will go for 9kg front and 7kg back but not sure wether I need to use 150mm front or 175mm?
I will be going for Geo3 rear knuckles and also adding in some body drop rear solid bushes to get it sat as low as I want
Thank you :)
Hi there,
The spring will react the same in 150mm and 175mm. The only limit will be the height but if you are using Geomasters you instantly get a 40/45mm RCA so you probably wont need the 150mm!
If you do order a set of CS2 and find you need the 150mm spring, give us an email and we can swap you out.
Cheers!
Hi there,
Cheers!
Perfect, thank you! Height I want to run on my s14 is tucking the top of the front tyre and tucking best part of the rear tyre static and about an inch squat under load. This is on 17's :)
