S14 drift parts
CorollaRWD
-RUTHLESS-
All parts are brand new
Nismo Steering rack bushes £45 per set
Nismo Power Brace 2 £100
Tein Steering tie rods gives more angle £75 per set
Largus Drift ARBs 190% front 240% uprated 280 per set
Alex
D-anie-l,
The ARBs drift specific and used by pretty much all of the D1 line up, would be really good for road/drift car as well as just drift because you could run softer spring rates for better ride but there wouldn't be any roll.
TwinturboCH
You got them already
Alex
CorollaRWD said:
D-anie-l,
TwinturboCH
Alex
Thought so, just checking. :D You haven't answered my PM :smash: :D
Al is it just the rod ends you have? as they don't give more angle, the tie rods themselves come with the spacers :)
Al, Put me down for a set of Steering rack bushes please :)
Should be over that way this weekend. I'll give you a call :)
Edited, cheers for pointing it out, it is in fact the tie rods with the spacers not the ends
Cool, how many set of the Tein rods do you have? Should be able to let you know by tommorrow.
Are they the tie rods and the ends together? Pretty sure you cant use the rods with standard ends and vice-versa.
Its just the tie rods, wasn't told that you had to use a tein end. Not sure if Phil or some one using them can clear it up?
Alex
Tein are weird in that you need both Tein rods and Tein ends, I think the ends may be the same as something from another nissan (Z32?), or at least the other nissan bit works with tein rods.
Phil said:
I think Z32 and R32 ends work on Tein arms, but don't quote me on it ;) I'm using Tein and Tein :)..
Well, I think you're right and wrong. From what Ive seen, although the threads are the same for Tein and R32/Z32, the rod end looks smaller on the Tein ones, hence why you dont hit the stops.
Could be wrong, but that's what I think ;)
