mittomatto said:argh! does anyone know if i can get some big cables or if the standard fronts bolt on with no alterations to where it bolts on
matt said:I have a full Z32 rear brake setup if you want it? don't need it anymore after I realised 5 stud is for cocksmokers
SXIV said:Surprising that the only S-chassis cars to have the disk/drum rear handbrake assembly were the Euro spec ones...
Anyway, its an easy job to swap for the S13/Z32/R33 rear setup and as Matt_S said the best choice for replacement handbrake cables are the R33 ones (they're about 2 inches too long compared to the S13 ones which are about 3 inches too short...). Blah blah blah, did this ages ago, you boys really need to keep up
mittomatto said:your missing the point. i dont want to swap for S13/Z32 or any model of skyline brakes!!! i just want to beef up the system and make the components as strong as i can. the standard e-brake is fine if you yank it hard enough
matt said:I realised 5 stud is for cocksmokers
mitchc said:When did you realise that? When you found you couldn't be fucked putting the work in to do the swap and source new rims?
