s14 handbrake
jimbo
Active Member
is there any decent/cheap/simple upgrade that can be done to an s14 handbrake/rear brakes coz mine is shit :nod: . as james said when i bought the car, the calipers probably just need freeing up. but because i`m a petrolhead i see this as an oppurtunity to put something better in its place instead:D is it true that skyline items will go straight on?
I believe skyline knucles will bolt straight on, Im sure someone will be along to correct me if Im wrong.
you need the lot from handbrake cables to knuckles to calipers to discs...
R32 (GTS/GTR) R33 (GTS/GTR) S13 and Z32 all fit and will dramatically improve the handbrake. a lot of D1 teams use standard R32 instead of power assisted hb's :nod:
theres no way in hell the Z32 hubs I have here would fit :wack:. Is there a big difference between NA and TT Z32 rear hubs?
driveshafts wouldnt fit...
shocks wouldnt fit...
I ended up putting S14 hubs onto the S13 knuckle and using the Z32 brake setup on that.
